APs Aruba 103
I have 2 APs Aruba 103 configured with the same SSID in the same network. The devices connected to the wifi start flapping betwen the two APs every 30 seconds. The devices are static, i mean they don´t move around the room.
Any solution for this flapping?
Thank you in advice.
Re: APs Aruba 103
Are these APs too close tot each other?
What type of client are you using ?
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Re: APs Aruba 103
About 25 - 30 meters.
Re: APs Aruba 103
What type of clients are you using ?
Are these IAP or Campus APs?
Thank you
Victor Fabian
Re: APs Aruba 103
The clients are barcode pistols and industrial label printers.
The APs are in IAP.
Re: APs Aruba 103
The power on your IAPs may be too high
I would try decreasing the power ,do you have ClientMatch on ?
Do you know what's the power set on those devices ? you probably want to match it
Thank you
Victor Fabian
