APs are not showing in Virtual controller
I have configured MY APs on aruba central i am able to see the devices in Central login.
Unfortunately i am getting 0 Access Points under local login virtual controller. this is happening for clients too.
Everything is visible on central Not on Local Virtual controller login.
If anyone had faced this issue and able to solve, please let me know what is the resolution.
Sunil
Frequent Contributor I
Re: APs are not showing in Virtual controller
you can tryo to disable your Internet connection, and see if you can see your AP in VC ?
Hi Sunil,
Please share a screenshot for the issue being observed.
Thanks for the kind reply... the issue has been resolved.
Since I was logging the Aruba Console through slave IP address was not able to see the IAP and client details.
Logged from Master IAP device IP address was able to see all the clients and AP details.
Sunil
