Occasional Contributor I
ARM only for a and g in controller
I have 2 Aruba 7030 controllers with ~60 AP 205 (802.11n/ac).
The problem is that in my controller, I can only change ARM for 802.11a and 802.11g (you can see it in the picture below).
Is there something I don't understand ?
Thank you
Re: ARM only for a and g in controller
802.11a and 802.11g should be considered the 5ghz and 2.4ghz spectrum, which are the only two bands that you have in wifi, whether it is 802.11ac or 802.11n.
Thank you very much !
