ARM
Two questions:
1. I am curious if ARM should automatically spread wireless channel, regardless of 2.4 or 5GHz, on APs on the the same floor in a building to avoid interference? If not, what CLI command to locate the AP-group profile to modify?
2. If the back-up master controller can't be seen or reached how does log of primary master contorller reflects that?
Please advise. Thanks,
Steve
Re: ARM
ARM should set the channels to minimize interference. For logging, you would need to use SNMP or Syslog, or AirWave.
Jerrod Howard
