Contributor II
ARUBA AP367 ANTENNA PATTERN PLOTS
Hi Everyone,
Anyone has this information? It doesn't appears in the DS,
Thanks.
Ricardo Luis Cañavate García - ACMP / ACCA / ACCP
Re: ARUBA AP367 ANTENNA PATTERN PLOTS
Jerrod Howard
Contributor II
Thanks a lot!
I can't see the attachment on this post?
Jay, if you click the links under my post, they should load (they do for me anyway).
Jerrod Howard
