Ability to see peak throughput on AP wired interface?
Is there a way on either the controller or Airwave to generate a report that shows peak throughput on the APs wired interface?  I was able to find average throughput in an Airwave report, but not peak.  One of the areas we are looking at improving is determining which areas would benefit from using multi-rate switches and APs, where the current gigabit interface is being bottlenecked.
