Contributor I
Access Point Second Ethernet Port
Is it possible to have an external device, such as a camera, connected to an access point's second Ethernet port and IPSEC tunnel (the access point will only have an Internet connection) that traffic back to the controller tagged as a different VLAN to the wireless traffic?
Re: Access Point Second Ethernet Port
Yes.
If you have the access point configured as a remote AP, you would set the forwarding mode of the ethernet port to tunnel and set the VLAN you want it to be on in the Wired AP profile.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
