Access point 325 not showing up after uograde.
Access points are not showing up in central after upgrade, currently in IAP state with version 6.5.4.0.-6. Upgrading the access points from version 6.5.0.0-4.3.0.0_56428 to 6.5.4.3_61959 but the upgrade continues to fail. Any one with the same problem?
Re: Access point 325 not showing up after uograde.
Is this a mixed cluste enviroment, i.e there is other models as well? Are you upgrading via a local image or from the cloud?
#show upgrade log
Do you see anything in the above log?
ACMA, ACMP, ACSA
If my post addresses your query, give kudos:)
