Access point does not allow conectivity
Hello All
I'm very new working with aruba devices, we are trying to deploy aruba network for the wireless network. We are using an Access point as controller and rbac Authentication, I did some conecctivity test with the controller and all the wlans was working fine, so I proceded to install the Access points in all the building.  I can reach all the APs by ping even they are shown in the controller anyway I was not able to connect with any AP.Cuould you please assist with this issue
Re: Access point does not allow conectivity
I would turn on user debugging for your device:
config t
logging level debug user-debug <mac address of device>
Try to connect to wireless and then type "show log user-debug all" to get a clue what could be happening..
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
