Access point without cabeling
I have ground and first floor with fibre connection (Modem) on first floor.
and i am unable to get proper signal on the ground floor and in my garden.
Is there any solution in aruba so that i can deploy accespoints in my first floor, ground floor and outdoor access point in  my garden... WITHOUT ANY CABELING FOR APS/ IAP
Re: Access point without cabeling
I don't believe so, you will need to run a cable from the modem to the AP.
If you have power on the ground floor, you can attempt to use mesh.
Tim Cappalli | Aruba Security
Yes. I have power supplies in the ground floors and garden areas to powerup the IAP.
So I can use IAP 205 oe iap 315... using this wireless mesh feature.
what are the things i have to take care of... while doing a site survey like
Howmuch should be the distance between IAPs and
How much signal strength is preferred at the place of second IAP to catch the signal from first IAP?
and any other recommendations???
