Access points AP-205 signal not stable
  • 1.  Access points AP-205 signal not stable
    Posted Apr 25, 2017 11:39 AM
    We have AP-205 installed in the hotel and its a new deployment too
    We installed AP in each room as per attached Heat map we are getting signal in each room with stable But when you roam around the corridor clients getting signal but move from one AP to other AP signals getting dropped and after 10-15 secs im getting the signal
    What could be the issue ? Coverage or Configuration issue
    Also attached picture of client roaming in corridor in red line where we are facing signal dropping issue but if you siwtch off the wifi and switch on you will get connecting again
    I totally fed up what could be the issue?
    Attachment(s)
    pdf
    2F HM.pdf   320 KB 1 version
  • 2.  RE: Access points AP-205 signal not stable
    Posted Apr 25, 2017 11:44 AM
    If you have an Android phone, you should download Aruba Utilities from the Play store. You should then go to the place where devices get dropped and take a screenshot of what signal strength are seen for that SSID where the device drops. That will give us, from a device perspective the signal strength that is seen.
    The Airwave heatmap shows coverage, but only from the access point perspective. We need something that will tell us coverage from the client perspective.
  • 3.  RE: Access points AP-205 signal not stable
    Posted Apr 25, 2017 11:46 AM
    I have only windows phone is there any tool for windows OS
  • 4.  RE: Access points AP-205 signal not stable
    Posted Apr 25, 2017 02:29 PM
    SSID is common for all Access points in the floors
  • 5.  RE: Access points AP-205 signal not stable
    Posted Apr 25, 2017 02:35 PM
    There is no tool for Windows mobile that we make, but do you have an app to tell you signal strength of access points where you get cut off?
  • 6.  RE: Access points AP-205 signal not stable
    Posted Apr 25, 2017 02:40 PM
    No i didnt have any application
  • 7.  RE: Access points AP-205 signal not stable
    Posted Apr 25, 2017 02:41 PM
    You need something to measure the signal strength in that area, otherwise we don't know if to turn the power up or down...
  • 8.  RE: Access points AP-205 signal not stable
    Posted Apr 25, 2017 02:47 PM
    There is no problem with signal coverage only when i roam from one ap to another signal dropping and then after 15-20 sec automatically it was showing full signal strength like that it was happening
  • 9.  RE: Access points AP-205 signal not stable
    Posted Apr 25, 2017 04:08 PM
    With client disconnects, coverage could be good, but the power could be either too high, too low or has alot of co-channel interference.  We need a client tool to understand what the environment is like to understand the next move to make.
  • 10.  RE: Access points AP-205 signal not stable
    Posted Apr 26, 2017 12:13 PM
    Is it possible to do site survey to add new ap in already AP deployed environment if so how to do that can anyone explain?
