Active-Active redundancy, Controller configuration is not synchronize
Hi All,
I have 2 Aruba Controllers in Active-Active redundancy configuration. They are running two instances of VRRP and each controller acts as the primary for one instance and backup for the other.
I found that the controller configuration are not synchronize so I need to input the configuration twice on each controller. Do I miss some steps or this is a consequences of using Active-Active redundancy?
Niko
Re: Active-Active redundancy, Controller configuration is not synchronize
Do you need the capacity of one controller or two? If you only need an n+1, you should make it a master/backup master redundancy:
You point the APs at a single VRRP instance between the controllers.
Only a single controller will work at a time.
Configurations will be synchronized.
If you need the capacity of two controllers, you need a master/local configuration where both controllers can actively terminate access points at the same time.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Hi Collin,
If we use master/local configuration, both controler configurations will able to synchronize right?
niko
Correct.
