Add standalone v8.1 Aruba controller to Mobility Master
My customer have a standalone Aruba controller with version 8.1 and now they need to add this controller to a Mobility Master they just bought.
Should I use a Migrating Tool to achive this or there is a some other way to do it?
I hope that I don't need to reinstall controller and configure it like MD to fix this problem. :-)
Thanks in advance.
Re: Add standalone v8.1 Aruba controller to Mobility Master
Well, anyone who can help me here with problem above?
Is this so difficult or unusual? :-)
I'm with you on this one.  I haven't been able to find any documentation on adding an existing standalone controller to a moblity master.  I think you may have to do it through the CLI. I'm trying to lab it up.
There is no automatic solution in importing an 8.1 standalone controller into an 8.1 MM, nor does the migration tool support this. Right now it will be a manual process of copying over the relevant device and group node config elements.
Jerrod Howard
