Contributor I
Adding Second VRRP Instance causes issues
having issues with VRRP on 6.1.2.5 as well, I'm alble to add one VRRP (1) instance without any issues.  As soon as I add a second VRRP (2) instace, VRRP freaks out.. and the second VRRP (2) instace becomes MASTER on both controllers.
I have tried with and without authentication.
Re: Adding Second VRRP Instance causes issues
What is the priority for each instance?  Do you have preempt enabled on either VRRP configuration?  What is your VRRP configuration for both instances?  In addition, use the command "show vrrp statistics" to report on what is seen on both controllers.
Colin Joseph
Aruba Customer Engineering
Super Contributor I
Also, define "freaks out". :-)
Realize that if you have "priority 255" set, that controller, no matter what, will try and be the master vrrp member. If both controllers in the VRRP pair are set to 255, they'll compete.
Ryan Holland, ACDX #1 ACMX #1
The Ohio State University
