Adding an SSID to APs
Hi, I'm a newbie.  How do you add an SSID to an AP?
Re: Adding an SSID to APs
Is this a new SSID that you want to add to a SINGLE AP, or it is a SSID that does not exist yet?
Colin Joseph
Aruba Customer Engineering
It's an existing SSID that is on some APs but now I want to add it to all the rest of the APs.
The smallest unit of an SSID is a Virtual AP profile.  To add an SSID to an AP or a group of APs, you need to figure out which AP group you want to add the SSID to.  When you find out, go to Configuration> Wireless> AP Configuration.  Click on the AP group that you want to add the SSID to.  Click on Wireless LAN.  Click on Virtual AP.  In the right pane, select the Virtual AP Profile (SSID) that you want to add, then click on Add.  Click on the Apply button in the lower right hand corner.
Click on Save Configuration to make it permanent.
On the Monitoring Tab, click on WLAN to see all of the access points that your SSID is on.
Colin Joseph
