Occasional Contributor I
Adhoc ssid
hi,
i have configured one SSID ex:
1) Airtel Wi-Fi
but when we see in wireless network connection it showing
Airtel Wi-Fiaaa
Airtel Wi-Fia
please suggest me what to do i have checked every thing in controller i am not able to find duplicate SSID
please helpppppp........
Re: Adhoc ssid
What device are you using where you see two SSIDs?
On the commandline, type "show wms ap list" to see the origin of those SSIDs.
Re: Adhoc ssid
we are using Ap 125 and on laptop we can see Two SSID
Re: Adhoc ssid
i don't know whether its a hidden SSID but how to identify
Re: Adhoc ssid
Are you seeing this on only one device or multiple devices.?
Re: Adhoc ssid
multiple devices
Re: Adhoc ssid
Please open a support case.
Re: Adhoc ssid
when i login to controller i can see only one SSID what i have created but when we go near to AP its broadcasting three SSID
one is what we created and the other two is may be its is duplicate or i dont know but how to find out the duplicate SSID .
