Admin and enable password script
Does anybody have a script to change the admin and enable password in the controller?
MVP
Re: Admin and enable password script
Um...
login
configure terminal
mgmt-user admin root <cr>
enter password
exit
write mem
--Matthew
if I've helped, please give kudos
if I've provided a solution, please mark the solution so others can find it
