Advisory Number 06062014 / CVE-2014-0224 - ArubaOS versions 5.x, 6.1.x, 6.2.x
According to the above advisory, the mentioned versions (5.x, 6.1.x, 6.2.x) are possibly affected.
Is there any more information on this as yet? Do we need to upgrade, or is there a fix released?
Many thanks,
Liam Burke
Re: Advisory Number 06062014 / CVE-2014-0224 - ArubaOS versions 5.x, 6.1.x, 6.2.x
POSSIBLY AFFECTED
	- ArubaOS 5.x, 6.1.x, 6.2.x
	- ArubaOS 7.x (Mobility Access Switch)
	  These versions contain an older version of OpenSSL which is not reported
	  to be vulnerable when acting as a TLS server.  Although Aruba does not
	  believe these versions pose a danger, OpenSSL will be patched during the
	  next scheduled maintenance cycle as a precaution
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
