Air Monitor and IDS
  • 1.  Air Monitor and IDS
    Posted Feb 26, 2013 10:25 AM
    I am using Aruba OS 6.1 and I have some questions:
    1. Is the receive sensitivity threshold parameter in the 802.11a/g radio settings basically control the RX sensitivity of the radio?
    2. Is the receive sensitivity parameter applicable to both AP and AM mode radios?
    3. When an IDS signature is added, where can I set the containment method used when a specific signature is found? Is this contained automatically based on the containment method under the IDS general profile?
    Thanks.
  • 2.  RE: Air Monitor and IDS
    Posted Mar 04, 2013 06:50 PM
    I'm 90% sure the answer to all 3 is yes. Would be good to get a second opinion though!
