Air Monitor working as AP
Our customer have 2 AP 105 working as AP and 1 AP105 working as Air Monitor at the same floor. They want to knows it is possible that the AM work automatically as AP, if there is a fail on any of the APs.
Thak you for your help
Wilson
Re: Air Monitor working as AP
You could try doing an AP specific profile for the AM AP. Put it in AP mode, and enable Mode-Aware ARM on just that AP. If the coverage is dense enough, it should convert itself into an AM and only change back if necessary (if the other AP fails).
You will need to test this out after hours at the location. Try what I said, then try disabling the normal AP. See if the Mode-Aware enabled AP turns itself back into an AP (assuming the coverage was strong enough for it to become an AM in the first place).
Are there only two APs at this site?
Zach Jennings
Yes, there are only 2 APs on that site.
Thank you
Wilson
Since there are only two APs at the site, I would definitely try the method I described above. If the first AP is providing enough coverage, the other AP (with mode-aware on) should turn itself into an AM.
Zach Jennings
