Contributor II
Air monitor Configuration
I created a new group for air monitors.  I edited the the rf profiles and changed the mode to AM.  I moved the AP into the group.
What is missing in the configuration?
Does the group need a VAP?
Does it need a AAA profile?
Does it need SSID profile?
In airwave the ap is showing down.
Brian Warren
Re: Air monitor Configuration
In Airwave, the radio might show down, but the device should be up.  It could say down because of the Airwave polling period.
You don't need a VAP, or AAA profile or an SSID profile, no.
