Contributor II
Air print not working
I have placed printer(airprint enabled) in VLAN 201 with SSID printer-MAC. and i have placed the ipad in vlan 201 with SSID-BYOD
as they are in same vlan , ipad should be able to scan the printer ri8!! but it is not able to scan printer in L2 domain.
For VAP printer-MAC, i have disabled drop broadcast and Multicast
For VAP BYOD, i have disabled drop broadcast and multicast
in the stateful firewall, i have disabled broadcast filter-arp.
Is there any configuration i have missed to make airprint to work????
Re: Air print not working
Are you running 6.3?  If so, try enabling Airgroup?
Seth R. Fiermonti
Consulting Systems Engineer - ACCX, ACDX, ACMX
Email: seth@hpe.com
If you found my post helpful, please give kudos
Contributor II
NO, controller is running on 6.2.14
I know that airgroup works across the subnets.
However now ipads and printer are in same vlan
