Regular Contributor I
AirGroup Firmware
I would like to upgrade 3800 controller firmware to the latest 6.1.x.x firmware that supports Air Group. Does anyone know which verision that would be?
I don't want to loose the "Plan" section of the controller because they do not have Airwave. I believe I can go into 6.2.x x firmware and keep the Plan but we have had a lot of problems in the past with anyting 6.2 it seems.
Recommendations?
Currently running 6.1.3.4-AirGroup
Re: AirGroup Firmware
6.1.3.6-Airgroup
http://support.arubanetworks.com/DownloadSoftware/tabid/75/DMXModule/510/EntryId/10709/Default.aspx
However, it is recommended to use fully support AirGroup code (6.3.x or 6.4.x).
Tim Cappalli | Aruba Security
