Occasional Contributor I
AirGroup MDNS Issue
After the latest Apple TV and Mac OS updates, we can no longer connect to our Apple TV over Airplay.
We were able to connect previously.
When I attempt to view the Airgroup settings in our Master, the page never loads.
When I attempt to run #show airgroup status, I get this message:
Module Multicast DNS Listener is busy. Please try later
I cannot run any Show commands at all.  I keep getting:
Is there a way to restart the Multicast DNS Listener module without rebooting the controller?
Re: AirGroup MDNS Issue
process restart mdns
Tim Cappalli | Aruba Security
Thanks Cappalli, but that didn't fix my issue.  I still can't run any commands or access the Airgroup page on the controllers web interface.
Any other ideas?
Try enabling debugging and then looking at the logs.
(config) #logging level debugging network process mdns
#show log network all | include mdns
Also, you may want to open a TAC case.
