Contributor II
AirGroup Question
We are trying to master the use of Airgroup on the controller and it seems like there isn't a whole ton of options. However, I was wondering if anybody has figured out (Without Clearpass) how to limit the list that gets brought up on the IPad.  I don't want to get as granual as per person but I was thinking more like per ap group or per vlan or something like that.  Has anybody done anything like this?  Is it even possible?
Re: AirGroup Question
You can block services via role:
config t
airgroupservice airplay
disallow-role Students
That will block anyone in the Students role from seeing any Airplay devices.
Can it be done per VLAN rather than per role?
It would be nice to limit users to seeing Airplay devices in their building.
Brad
There is an option for that.
Aruba
To disallow a VLAN:
   disallow-vlan <id>
To cofirm:
show airgroupservice
show airgroup vlan
AMFX | ACCX | ACDX | ACMX
I'm not looking to disallow AirGroup, I'm looking to isolate it by building.
Brad
Aruba
Sorry, thought you asked how to do it by VLAN?  How are you differentiating your buildings?  Roles?  VLANs?   AP Groups?
Contributor II
It would be nice if you can do it per Ap-group land vlan. However, if somehow we can't figure out how to do it with one of them that would work.
Example would be-
ipad connects to ap group ms. It sees list apple devices only in the ms ap group and/or certain vlan.
Then ipad connects to app in HS group and that iPad only sees ones in the Hs ap group and/or a certain vlan.
Make sense?
John,
It does make sense. Please post to the ideas portal.
Quick question, how are you using it today.
Trusted Contributor I
i believe this is already possible with an airgroup intergrated setup, you can do something with the AP group and vlan if im not mistaken.
