AirPrint does not work on wireless clients on local controllers
  • 1.  AirPrint does not work on wireless clients on local controllers
    Posted Feb 15, 2018 06:14 AM
    We're in the process of installing a new printing service for Apple devices called Wide Area Mobile Print (part of the EveryonePrint solution). The solution runs on a server connected to the wired network at the central office. The server VLAN is trunked to the master controller, and printing works from wireless clients connected to access points on the master controller. If we connect the same client to an AP on a local controller it stops working - the client cannot connect to the printer. There is nothing in our firewall logs, so I suspect that there is something missing in our WLAN config. We have enabled AirPrint on all the controllers.
    We are using 7240/7210 controllers running ArubaOS 6.5.3.3
  • 2.  RE: AirPrint does not work on wireless clients on local controllers
    Posted Feb 15, 2018 08:25 AM
    Update: nevermind, we got it to work eventually. Turned out to be a routing problem.
