AirWave does not report client counts from APs on local controller
So, both my master and local controller are up in AirWave, I can see that some APs are on the master, others on the local controller, though, all APs on the local controller report 0 client. Which I know isn't correct since i can see clients on these APs if I go to the local controller web page.
The total client counts displayed on the top header also affected since AirWave only count the clients from the master controller.
Any idea ? I'm using AirWave 8.2.6.
thanks
Re: AirWave does not report client counts from APs on local controller
What version of ArubaOS is this?
Did you follow the instructions to add your controller to Airwave with SNMP and AMON?
Ugh, yeah, my AirWave server wasn't defined on my local controller config!
Thanks!
