Frequent Contributor I
Airgroup for ClickShare
Has anyone ClickShare presentation devices integrated in an Aruba Campus enviroment?
I have a white paper for integration into corporate networks, which also shows posibillity to get access from dedicated guest networks if you route between them but i think i need airgroup also
I found this in the whitepaper:
"Airplay and Google cast, as well as the ClickShare App require multicast to make the ClickShare Base Unit discoverable within your network.
Therefore, allowing multicast within the network is required to use Airplay and Google Cast. The Base Unit should be connected in the same
subnet as the mobile device or a network connection should be available from the mobile device to the Base Unit. "
