Super Contributor II
Airgroup with Bridged AP's
HI All,
Just wondering if somene could advise whether Airgroup services will work on an AP that is deployed in a bridge forwarding mode?
Scot
Re: Airgroup with Bridged AP's
AirGroup is supported only in tunnel and decrypt-tunnel forwarding modes
Thank you
Victor Fabian
Lead Mobility Architect @WEI
thanks victor.
What if the VAP is split-tunnel and multicast sent to controller with
user 240.0.0.0 240.0.0.0 any permit
ACCP, ACCX #817, ACMP, ACMX #294
