I have been using airgoup for airplay for a pool of vlans without any issue, now our requirment has changed, we will have two SSID's with two vlan pools, is there a way to restrict the bonjour devices (in our case AppleTv) in one SSID (vlan associated with one ssid) from advertised on to the other SSID users. We do not have clearpass.
Thank you
Re: Airgroup
There is no way to do that without clearpass comprehensively.
Without ClearPass, You could disallow VLANs globally to block airgroup visibility into those VLANs.  You could also block airgroup services by role.
To selectively allow users to see resources in one VLAN and block others from seeing the same thing, you need clearpass.
Colin Joseph
Aruba Customer Engineering
