Airware Installation
Hello All,
I want to installed the Airware 7.1.3 on our machine. i have download AMP-7.1.3.iso from support site and burn on CD.
it's 32-bit ISO.   when i boot the CD this message appear.
"ISOLINUX: 3.11 2005-09-02 Copyright (C) 1994-2005 H. Peter Aavin:
cound not find kernel image: linux
Please guide how to installed Airware.
Re: Airware Installation
You may need to re-download the image.  Also, you should get the latest version - 7.4.7.  It's a 64-bit image.  You just mount the ISO and install.  Follow the prompts, fairly easy.
Thanks Friend for your response. but i have only 32-bit machine right now. so please help to successfully installation on this machine.
You may want to re-download.  Also, there is v7.3.8 for 32Bit systems.
To see if the file is corrupted, check the md5.  Here is the md5sum for 7.1.3 32bit ISO:
md5sum = b7abae4a7da7ecd7b9d095a2bfc11842
Compare it to your copy using a md5 checker.
