Airwave 8.2.0 not showing rogues
I recently noticed my Airwave server (version 8.2.0) was not showing any rogues. My controller however is. I wanted to see if anybody had this issue or knew of a way to change the settings back to default in case i acciedntly messed up a setting.
Re: Airwave 8.2.0 not showing rogues
We ran into this problem with our two Airwave Instances and I discovered the following in our logs that continuously occured with eachother ever since we upgraded to Airwave 8.2:
1. Airwave Logs:  Error in SNMP polling: Timeout(thin_ap_rogue_client
2. ArubaOS Logs: snmp[4156]: <301247> <WARN> Processing of GET(next) request failed
We contacted TAC and they've ran into this problem before. They have a patch for this issue, believe it was called, RAPIDS_FIX_8201. Note this also affected our "AP Neighbors" under "AP Monitoring".
This issue seems fixed in Airwave 8.2.0.2. From the release notes:
DE25333 Symptom: An issue is resolved where AirWave was processing incoming rogue data but not
correctly updating the AP database.
Scenario: In a previous releases of AirWave 8.2.x, rogue AP data was processed by AirWave
but not stored in the database, preventing rogue devices from correctly appearing in the
RAPIDs overview pages.
