Airwave Setting - 802.1x supplicant support for IAP
Is it possible to set the 802.1x settings on IAP Uplink in Instant Cluster for all IAPs (205/215) ?
I need to push the certificate and PEAP User on 55 AP's.
And for regular maintanence I have to change the PEAP Credentials.
Is this possible in Airwave and how ?
The "manual" was is described in:802.1x supplicant support for IAP
I'm looking for an automated way.....
Airwave Version 8.2.2.1 and IAP FW 6.4.4.8-4.2.4.3
