Alcatel-Lucent AP205 pwr led keeps blinking
Hi all,
I got 2 APs 205 and both of them have the same issue, their pwr leds keep blinking and do not turn steady.
Moreover, I try connecting them with a controller, model 6000. However, the controller couldnt recognize their mac address. Mean while, it could regconize other 207 ap.
Does anyone have a solution to my problem?
Re: Alcatel-Lucent AP205 pwr led keeps blinking
Are these instant APs or campus APs?
What version of code is running on the controller?
They are campus.
The firmware of the controller is 6.1.3.5.
The minimum software version required for the AP205 is 6.4.1.0:  http://www.arubanetworks.com/assets/ds/DS_AP200Series.pdf
The minimum software version required for the AP207 is 6.5.1.0:
http://www.arubanetworks.com/assets/ds/DS_AP207Series.pdf
