Occasional Contributor I
All APs in monitor mode
I have a question in my controller in Air monitor is showing that I have 247 air monitor, but this does not seem right because it is almost the number of APs we have. I was told there was no configuration change and after that show that they are as monitor also shows that APs are access.
What can this be?
Reinaldo
Re: All APs in monitor mode
Run show audit-trail on your controller to verify that no configuration change was made.
Tim
Tim Cappalli | Aruba Security
I'll check...
Reinaldo
And still did not get the customer to exit the command, but had asked before other commands. I put here simply.
From what I understand the Aps are the band 11g as access and 11th as Monitor. Therefore appear on both lists am I correct?
How to change in order to maintain only the original monitor?
#show ap active type air-monitor
Active AP Table
Name Group IP Address 11g Clients 11g Ch/EIRP/MaxEIRP 11a Clients 11a Ch/EIRP/MaxEIRP AP Type Flags Uptime Outer IP
HC1-AP-9A 04 HOSPITAL1-HC1-CONTROLLER01 10.46.12.69 0 0 AM 125 Aa 29d:5h:21m:32s N/A
HC1-MON-5A 01 MONITOR - HC1 - CONTROLLER-01 10.46.14.70 0 AM 0 AM 125 Aa 29d:5h:17m:29s N/A
HC1-AP-6A 02 HOSPITAL1-HC1-CONTROLLER01 10.46.14.71 0 0 AM 125 Aa 5d:7h:5m:37s N/A
#show ap active type access-point
Active AP Table
HC1-AP-9A 04 HOSPITAL1-HC1-CONTROLLER01 10.46.12.69 3 AP:HT:6/20.5/20.5 0 125 Aa 29d:5h:22m:1s N/A
HC1-AP-6A 02 HOSPITAL1-HC1-CONTROLLER01 10.46.14.71 13 AP:HT:6/20.5/20.5 0 125 Aa 5d:7h:6m:6s N/A
Change the radio profile back to ap-mode.
You'll want to create a new AP group for your Air Monitor with new radio profiles that are in AM-mode. Then reprovision your AP into the air monitor AP group.
