Am I able to see clients name instead of clients IP adress or Mac address on Monitoring -Clients tab
Re: Am I able to see clients name instead of clients IP adress or Mac address on Monitoring -Clients
Is this MAC authentication?  If so, then you will not be able to see it.
Seth R. Fiermonti
Consulting Systems Engineer - ACCX, ACDX, ACMX
Email: seth@hpe.com
If you found my post helpful, please give kudos
If you are using ClearPass with MAC auth, you can return a username from an external source.
If you are using PSK and/or MAC auth independently, you will not see any user information.
Tim Cappalli | Aruba Security
