Frequent Contributor I
Android 7.x Phone sending deauth code 3
So one of the clients is getting random disconnection for some reason. Log says Code 3 reason or the way I understand it is the phone itself is initiating the deauth. He has a Motorola Android 7.x phone. What is really surprising is I have an LG phone with Android 7.x too but I don't have this problem. Any ideas? Here's the log.
(aruba-wc2) #  show auth-tracebuf mac d4:63:c6:xx:xx:2x
Warning: user-debug is enabled on one or more specific MAC addresses;
         only those MAC addresses appear in the trace buffer.
Auth Trace Buffer
Dec  1 13:53:51  station-down           *  d4:63:c6:xx:xx:2x  18:64:72:38:71:d2                    -  -
Dec  1 13:54:07  station-up             *  d4:63:c6:xx:xx:2x  18:64:72:38:71:d2                    -  -    wpa2 aes
Dec  1 13:54:07  wpa2-key1             <-  d4:63:c6:xx:xx:2x  18:64:72:38:71:d2                    -  117
Dec  1 13:54:07  wpa2-key2             ->  d4:63:c6:xx:xx:2x  18:64:72:38:71:d2                    -  135
Dec  1 13:54:07  wpa2-key3             <-  d4:63:c6:xx:xx:2x  18:64:72:38:71:d2                    -  167
Dec  1 13:54:07  wpa2-key4             ->  d4:63:c6:xx:xx:2x  18:64:72:38:71:d2                    -  95
Dec  1 14:01:05  station-down           *  d4:63:c6:xx:xx:2x  18:64:72:38:71:d2                    -  -
Dec  1 14:01:16  station-up             *  d4:63:c6:xx:xx:2x  18:64:72:38:71:d2                    -  -    wpa2 aes
Dec  1 14:01:16  wpa2-key1             <-  d4:63:c6:xx:xx:2x  18:64:72:38:71:d2                    -  117
Dec  1 14:01:16  wpa2-key2             ->  d4:63:c6:xx:xx:2x  18:64:72:38:71:d2                    -  135
Dec  1 14:01:16  wpa2-key3             <-  d4:63:c6:xx:xx:2x  18:64:72:38:71:d2                    -  167
Dec  1 14:01:16  wpa2-key4             ->  d4:63:c6:xx:xx:2x  18:64:72:38:71:d2                    -  95
Dec  1 14:03:16  rad-acct-int-update   ->  d4:63:c6:xx:xx:2x  18:64:72:38:71:d2/radius-01-eduroam  -  -
Dec  1 14:03:16  rad-acct-int-update   ->  d4:63:c6:xx:xx:2x  18:64:72:38:71:d2/radius-02-eduroam  -  -
(aruba-wc2) #
(aruba-wc2) #show log user-debug all | include d4:63:c6:xx:xx:2x
Dec 1 13:54:07 :522259:  <DBUG> |authmgr|  "VDR - Do Role Based VLAN Derivation user d4:63:c6:xx:xx:2x role cpp-role-authenticated rolehow ROLE_DERIVATION_DOT1X_VSA.
Dec 1 13:54:07 :522254:  <DBUG> |authmgr|  VDR - mac d4:63:c6:xx:xx:2x rolename cpp-role-authenticated fwdmode 0 derivation_type Dot1x Aruba VSA Role Contained vp not present.
Dec 1 13:54:07 :522258:  <DBUG> |authmgr|  "VDR - Add to history of user user d4:63:c6:xx:xx:2x vlan 0 derivation_type Reset Role Based VLANs index 7.
Dec 1 13:54:07 :522255:  <DBUG> |authmgr|  "VDR - set vlan in user for d4:63:c6:xx:xx:2x vlan 1521 fwdmode 0 derivation_type Current VLAN updated.
Dec 1 13:54:07 :522258:  <DBUG> |authmgr|  "VDR - Add to history of user user d4:63:c6:xx:xx:2x vlan 1521 derivation_type Current VLAN updated index 8.
Dec 1 13:54:07 :522260:  <DBUG> |authmgr|  "VDR - Cur VLAN updated d4:63:c6:xx:xx:2x mob 0 inform 1 remote 0 wired 0 defvlan 1521 exportedvlan 0 curvlan 1521.
Dec 1 13:54:07 :522029:  <INFO> |authmgr|  MAC=d4:63:c6:xx:xx:2x Station authenticate: method=802.1x, role=cpp-role-authenticated/cpp-role-authenticated//guest-logon, VLAN=1521/1521, Derivation=9/1, Value Pair=0
Dec 1 13:54:07 :522158:  <DBUG> |authmgr|  Role Derivation for user 10.110.166.196-d4:63:c6:xx:xx:2x-amulyadi@cpp.edu N/A User authenticated with auth type:Unknown auth type role derivation:0.
Dec 1 13:54:07 :522318:  <DBUG> |authmgr|  Client d4:63:c6:xx:xx:2x idle timeout 300 profile global
Dec 1 13:54:07 :522008:  <NOTI> |authmgr|  User Authentication Successful: username=amulyadi@cpp.edu MAC=d4:63:c6:xx:xx:2x IP=10.110.166.196 role=cpp-role-authenticated VLAN=1521 AP=015-2000-ap07-w1 SSID=eduroam AAA profile=cpp-aaa-dot1x-eduroam auth method=802.1x auth server=radius-01-eduroam
Dec 1 13:54:07 :522158:  <DBUG> |authmgr|  Role Derivation for user fe80::d663:c6ff:fe43:4b25-d4:63:c6:xx:xx:2x-amulyadi@cpp.edu N/A User authenticated with auth type:Unknown auth type role derivation:0.
Dec 1 13:54:07 :522008:  <NOTI> |authmgr|  User Authentication Successful: username=amulyadi@cpp.edu MAC=d4:63:c6:xx:xx:2x IP=fe80::d663:c6ff:fe43:4b25 role=cpp-role-authenticated VLAN=1521 AP=015-2000-ap07-w1 SSID=eduroam AAA profile=cpp-aaa-dot1x-eduroam auth method=802.1x auth server=radius-01-eduroam
Dec 1 13:54:07 :522301:  <DBUG> |authmgr|  Auth GSM : USER publish for uuid 0x88724b02e09839a7 mac d4:63:c6:xx:xx:2x name amulyadi@cpp.edu role cpp-role-authenticated devtype Android wired 0 authtype 4 subtype 9  encrypt-type 10 conn-port 8448 fwd-mode 0
Dec 1 13:54:07 :522243:  <DBUG> |authmgr|  MAC=d4:63:c6:xx:xx:2x Station Updated Update MMS: BSSID=18:64:72:38:71:d2 ESSID=eduroam VLAN=1521 AP-name=015-2000-ap07-w1
Dec 1 13:54:10 :527000:  <DBUG> |mdns|  mdns_parse_auth_userapname_message 452 Auth->MDNS User APNAME: MAC:d4:63:c6:xx:xx:2x, NEW AP NAME:015-2000-ap07-w1
Dec 1 13:54:10 :527000:  <DBUG> |mdns|  mdns_parse_auth_userrole_message 269 Auth User ROLE: MAC:d4:63:c6:xx:xx:2x, ROLE_NAME:cpp-role-authenticated
Dec 1 13:54:10 :527000:  <DBUG> |mdns|  mdns_auth_userinfo_req_message 345 mac(d4:63:c6:xx:xx:2x), ip(10.110.166.196)
Dec 1 13:54:15 :527000:  <DBUG> |mdns|  mdns_parse_userinfo 376 UserInfo resp=1 ip=10.110.166.196, mac=d4:63:c6:xx:xx:2x, apname=015-2000-ap07-w1, role=cpp-role-authenticated, username=amulyadi@cpp.edu, vlan=1521
Dec 1 13:54:15 :527000:  <DBUG> |mdns|  ag_mdns_get_token_list_for_mac 654 AirGroup user exists but token_list does not: mac=d4:63:c6:xx:xx:2x
Dec 1 13:54:15 :527000:  <DBUG> |mdns|  ag_ssdp_get_token_list_for_mac 360 AirGroup user exists but ssdp_token_list does not: mac=d4:63:c6:xx:xx:2x
Dec 1 13:54:15 :527000:  <DBUG> |mdns|  mdns_parse_auth_userinfo_resp_message 401 UserInfo response completed for ip=10.110.166.196 mac=d4:63:c6:xx:xx:2x
Dec 1 14:01:06 :501105:  <NOTI> |AP 015-2000-ap07-w1@10.111.19.254 stm|  Deauth from sta: d4:63:c6:xx:xx:2x: AP 10.111.19.254-18:64:72:38:71:d2-015-2000-ap07-w1 Reason STA has left and is deauthenticated
Dec 1 14:01:06 :522296:  <DBUG> |authmgr|  Auth GSM : USER_STA delete event for user d4:63:c6:xx:xx:2x age 0 deauth_reason 3
Dec 1 14:01:06 :522036:  <INFO> |authmgr|  MAC=d4:63:c6:xx:xx:2x Station DN: BSSID=18:64:72:38:71:d2 ESSID=eduroam VLAN=1521 AP-name=015-2000-ap07-w1
Dec 1 14:01:06 :501000:  <DBUG> |AP 015-2000-ap07-w1@10.111.19.254 stm|  Station d4:63:c6:xx:xx:2x: Clearing state
Dec 1 14:01:06 :522234:  <DBUG> |authmgr|  Setting idle timer for user d4:63:c6:xx:xx:2x to 300 seconds (idle timeout: 300 ageout: 0).
Dec 1 14:01:06 :501000:  <DBUG> |stm|  Station d4:63:c6:xx:xx:2x: Clearing state
Dec 1 14:01:16 :501093:  <NOTI> |AP 015-2000-ap07-w1@10.111.19.254 stm|  Auth success: d4:63:c6:xx:xx:2x: AP 10.111.19.254-18:64:72:38:71:d2-015-2000-ap07-w1
Dec 1 14:01:16 :501095:  <NOTI> |AP 015-2000-ap07-w1@10.111.19.254 stm|  Assoc request @ 14:01:16.430349: d4:63:c6:xx:xx:2x (SN 3262): AP 10.111.19.254-18:64:72:38:71:d2-015-2000-ap07-w1
Dec 1 14:01:16 :501100:  <NOTI> |stm|  Assoc success @ 14:01:16.437800: d4:63:c6:xx:xx:2x: AP 10.111.19.254-18:64:72:38:71:d2-015-2000-ap07-w1
Dec 1 14:01:16 :501100:  <NOTI> |AP 015-2000-ap07-w1@10.111.19.254 stm|  Assoc success @ 14:01:16.431301: d4:63:c6:xx:xx:2x: AP 10.111.19.254-18:64:72:38:71:d2-015-2000-ap07-w1
Dec 1 14:01:16 :522295:  <DBUG> |authmgr|  Auth GSM : USER_STA event 0 for user d4:63:c6:xx:xx:2x
Dec 1 14:01:16 :522035:  <INFO> |authmgr|  MAC=d4:63:c6:xx:xx:2x Station UP: BSSID=18:64:72:38:71:d2 ESSID=eduroam VLAN=1521 AP-name=015-2000-ap07-w1
Dec 1 14:01:16 :522077:  <DBUG> |authmgr|  MAC=d4:63:c6:xx:xx:2x ingress 0x0x1042d (tunnel 1069), u_encr 64, m_encr 4112, slotport 0x0x2100 , type: local, FW mode: 0, AP IP: 0.0.0.0 mdie 0 ft_complete 0
Dec 1 14:01:16 :522078:  <DBUG> |authmgr|  MAC=d4:63:c6:xx:xx:2x, wired: 0, vlan:1521 ingress:0x0x1042d (tunnel 1069), ingress:0x0x1042d new_aaa_prof: cpp-aaa-dot1x-eduroam, stored profile: cpp-aaa-dot1x-eduroam stored wired: 0 stored essid: eduroam, stored-ingress: 0x0x1042d
Dec 1 14:01:16 :522247:  <DBUG> |authmgr|  User idle timer removed for user with  MAC d4:63:c6:xx:xx:2x.
Dec 1 14:01:16 :522258:  <DBUG> |authmgr|  "VDR - Add to history of user user d4:63:c6:xx:xx:2x vlan 0 derivation_type Reset VLANs for Station up index 9.
Dec 1 14:01:16 :522255:  <DBUG> |authmgr|  "VDR - set vlan in user for d4:63:c6:xx:xx:2x vlan 1521 fwdmode 0 derivation_type Default VLAN.
Dec 1 14:01:16 :522258:  <DBUG> |authmgr|  "VDR - Add to history of user user d4:63:c6:xx:xx:2x vlan 1521 derivation_type Default VLAN index 10.
Dec 1 14:01:16 :522255:  <DBUG> |authmgr|  "VDR - set vlan in user for d4:63:c6:xx:xx:2x vlan 1521 fwdmode 0 derivation_type Current VLAN updated.
Dec 1 14:01:16 :522258:  <DBUG> |authmgr|  "VDR - Add to history of user user d4:63:c6:xx:xx:2x vlan 1521 derivation_type Current VLAN updated index 11.
Dec 1 14:01:16 :522158:  <DBUG> |authmgr|  Role Derivation for user N/A-d4:63:c6:xx:xx:2x-amulyadi@cpp.edu N/A Set AAA profile defaults.
Dec 1 14:01:16 :522246:  <DBUG> |authmgr|  Idle timeout should be driven by STM for MAC d4:63:c6:xx:xx:2x.
Dec 1 14:01:16 :524141:  <DBUG> |authmgr|  clr_pmkcache_ft():987: MAC:d4:63:c6:xx:xx:2x BSS:18:64:72:38:71:d2
Dec 1 14:01:16 :522287:  <DBUG> |authmgr|  Auth GSM : MAC_USER publish for mac d4:63:c6:xx:xx:2x bssid 18:64:72:38:71:d2 vlan 1521 type 1 data-ready 0
Dec 1 14:01:16 :522254:  <DBUG> |authmgr|  VDR - mac d4:63:c6:xx:xx:2x rolename guest-logon fwdmode 0 derivation_type Initial Role Contained vp not present.
Dec 1 14:01:16 :522258:  <DBUG> |authmgr|  "VDR - Add to history of user user d4:63:c6:xx:xx:2x vlan 0 derivation_type Reset Role Based VLANs index 12.
Dec 1 14:01:16 :524124:  <DBUG> |authmgr|  dot1x_supplicant_up(): MAC:d4:63:c6:xx:xx:2x, pmkid_present:True, pmkid:62 83 69 da 8a d1 d2 ec 7d 53 53 c2 30 75 c1 99
Dec 1 14:01:16 :522142:  <DBUG> |authmgr|  Setting cached role to cpp-role-authenticated for user d4:63:c6:xx:xx:2x".
Dec 1 14:01:16 :522254:  <DBUG> |authmgr|  VDR - mac d4:63:c6:xx:xx:2x rolename NULL fwdmode 0 derivation_type VLAN from pmk-cache vp not present.
Dec 1 14:01:16 :522044:  <INFO> |authmgr|  MAC=d4:63:c6:xx:xx:2x Station authenticate(start): method=802.1x, role=cpp-role-authenticated/cpp-role-authenticated//guest-logon, VLAN=1521/1521, Derivation=9/1, Value Pair=0, flags=0x8
Dec 1 14:01:16 :522158:  <DBUG> |authmgr|  Role Derivation for user N/A-d4:63:c6:xx:xx:2x-amulyadi@cpp.edu N/A station Authenticated with auth type:  Unknown auth type.
Dec 1 14:01:16 :522127:  <DBUG> |authmgr|  {L2} Update role from cpp-role-authenticated to cpp-role-authenticated for IP=N/A, MAC=d4:63:c6:xx:xx:2x.
Dec 1 14:01:16 :522049:  <INFO> |authmgr|  MAC=d4:63:c6:xx:xx:2x,IP=N/A User role updated, existing Role=cpp-role-authenticated/none, new Role=cpp-role-authenticated/none, reason=station Authenticated with auth type:  802.1x
Dec 1 14:01:16 :522050:  <INFO> |authmgr|  MAC=d4:63:c6:xx:xx:2x,IP=N/A User data downloaded to datapath, new Role=cpp-role-authenticated/95, bw Contract=0/0, reason=Download driven by user role setting, idle-timeout=300
Dec 1 14:01:16 :522301:  <DBUG> |authmgr|  Auth GSM : USER publish for uuid 0x88724b02e09839a7 mac d4:63:c6:xx:xx:2x name amulyadi@cpp.edu role cpp-role-authenticated devtype Android wired 0 authtype 4 subtype 9  encrypt-type 10 conn-port 8448 fwd-mode 0
Dec 1 14:01:16 :522259:  <DBUG> |authmgr|  "VDR - Do Role Based VLAN Derivation user d4:63:c6:xx:xx:2x role cpp-role-authenticated rolehow ROLE_DERIVATION_DOT1X_VSA.
Dec 1 14:01:16 :522254:  <DBUG> |authmgr|  VDR - mac d4:63:c6:xx:xx:2x rolename cpp-role-authenticated fwdmode 0 derivation_type Dot1x Aruba VSA Role Contained vp not present.
Dec 1 14:01:16 :522258:  <DBUG> |authmgr|  "VDR - Add to history of user user d4:63:c6:xx:xx:2x vlan 0 derivation_type Reset Role Based VLANs index 13.
Dec 1 14:01:16 :522258:  <DBUG> |authmgr|  "VDR - Add to history of user user d4:63:c6:xx:xx:2x vlan 1521 derivation_type Current VLAN updated index 14.
Dec 1 14:01:16 :522260:  <DBUG> |authmgr|  "VDR - Cur VLAN updated d4:63:c6:xx:xx:2x mob 0 inform 1 remote 0 wired 0 defvlan 1521 exportedvlan 0 curvlan 1521.
Dec 1 14:01:16 :522029:  <INFO> |authmgr|  MAC=d4:63:c6:xx:xx:2x Station authenticate: method=802.1x, role=cpp-role-authenticated/cpp-role-authenticated//guest-logon, VLAN=1521/1521, Derivation=9/1, Value Pair=0
Dec 1 14:01:16 :522158:  <DBUG> |authmgr|  Role Derivation for user 10.110.166.196-d4:63:c6:xx:xx:2x-amulyadi@cpp.edu N/A User authenticated with auth type:Unknown auth type role derivation:0.
Dec 1 14:01:16 :522318:  <DBUG> |authmgr|  Client d4:63:c6:xx:xx:2x idle timeout 300 profile global
Dec 1 14:01:16 :522008:  <NOTI> |authmgr|  User Authentication Successful: username=amulyadi@cpp.edu MAC=d4:63:c6:xx:xx:2x IP=10.110.166.196 role=cpp-role-authenticated VLAN=1521 AP=015-2000-ap07-w1 SSID=eduroam AAA profile=cpp-aaa-dot1x-eduroam auth method=802.1x auth server=radius-01-eduroam
Dec 1 14:01:16 :522158:  <DBUG> |authmgr|  Role Derivation for user fe80::d663:c6ff:fe43:4b25-d4:63:c6:xx:xx:2x-amulyadi@cpp.edu N/A User authenticated with auth type:Unknown auth type role derivation:0.
Dec 1 14:01:16 :522008:  <NOTI> |authmgr|  User Authentication Successful: username=amulyadi@cpp.edu MAC=d4:63:c6:xx:xx:2x IP=fe80::d663:c6ff:fe43:4b25 role=cpp-role-authenticated VLAN=1521 AP=015-2000-ap07-w1 SSID=eduroam AAA profile=cpp-aaa-dot1x-eduroam auth method=802.1x auth server=radius-01-eduroam
Dec 1 14:01:16 :522243:  <DBUG> |authmgr|  MAC=d4:63:c6:xx:xx:2x Station Updated Update MMS: BSSID=18:64:72:38:71:d2 ESSID=eduroam VLAN=1521 AP-name=015-2000-ap07-w1
Dec 1 14:01:19 :527000:  <DBUG> |mdns|  mdns_parse_auth_userapname_message 452 Auth->MDNS User APNAME: MAC:d4:63:c6:xx:xx:2x, NEW AP NAME:015-2000-ap07-w1
Dec 1 14:01:19 :527000:  <DBUG> |mdns|  mdns_parse_auth_userrole_message 269 Auth User ROLE: MAC:d4:63:c6:xx:xx:2x, ROLE_NAME:cpp-role-authenticated
Dec 1 14:01:19 :527000:  <DBUG> |mdns|  mdns_auth_userinfo_req_message 345 mac(d4:63:c6:xx:xx:2x), ip(10.110.166.196)
(aruba-wc2) #
Re: Android 7.x Phone sending deauth code 3
Code 3 description here:  http://community.arubanetworks.com/t5/Technology-Blog/802-11-Reason-Codes-and-Status-Codes/ba-p/257893
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Yes I saw this  link a while ago. The thing is, client is not moving at all. The Client devices initiates deauth and connects to the same AP for no reason at all. I want to understand if this is a client device issue or some setting on the controller can fix this issue.
What version of ArubaOS is this?
What model access point is this?
AOS 6.4.4.16
AP225
thanks.
Do you have 802.11r, v or k enabled on that SSID?
UPDATE 6/2018 -  The updated RF and Roaming Optimization Validated Reference Design Guide (VRD) has been published and has updated recommendations about enabling 802.11v, k and r in user networks.  The VRD can be found here: http://community.arubanetworks.com/t5/Validated-Reference-Design/RF-and-Roaming-Optimization-for-Aruba-802-11ac-Networks/ta-p/432994
Hi Cjoseph,
Where can I exactly find these? Checked the SSID profile and I don't seem to find them in there.
NVM- I found it. It is pointing to N/A profile. Should I make a profile? What settings should I put?
If they are not enabled, that is good.  You might want to open a tac case so that they can look through your configuration for clues.  It is hard to review a configuration on the forum here.
