Trusted Contributor I
Android with Aruba TLS SSID
im trying to setup an EAP TLS protected SSID, it works for my Windows 8 laptop. but my Android 4.0.4 phone simply doesn't want to connect. when googling for android (EAP) TLS / Wifi / ... i find lots of complaining and such, but not even basic information on how to configure it.
is there anyone here who has EAP TLS working between Aruba (or other vendor) and an Android device?
I have imported my client certificate and the CA which signed it on the Android device. I also imported the CA certificate that signed the controller certificate (not an offical CA btw).
my current wifi settings on the Android are:
EAP method: TLS
Phae 2: None
CA certificate: the CA for the client certificate (unsure why i need to provide this)
User certificate: the client certificate
Identity: Empty
Anonymous identity: Empty
Password: Empty
Moderator
Re: Android with Aruba TLS SSID
Hi
You should use the following settings:
EAP method: TLS
Phae 2: None
CA certificate: the CA for the client and Server certificate
Identity: <user id>
Password: Empty
CA certificate: You should provide the certificate of the CA signing both your certificate and the AAA server's. This has to be provided in order to securely validate the server ID.
Identity: You should provide your identity. I'm not sure if it's compulsory but in this field you usually enter the same id you used to generate the client certificate.
If all that is ok and your WLAN still doesn't work, make sure you've imported your certificates properly. The client certificate should be a .pem cert containing the private key. The CA certificate only has to have the public key, and .cer format should work.
Try it and tell us if you still have any issues.
Regards
Samuel Pérez
ACMP, ACCP, ACDX#100
If I answerd your question, please click on "Accept as Solution".
If you find this post useful, give me kudos for it ;)
thank you, one thing that is certainly different is the CA for the client and the server certificate. is it compulsory that it is the same? because for example with a laptop it isn't.
Moderator
Hi
It was a simplification. What you really need is the server certificate to be signed by a a CA that's trusted in your phone. The same happens on the other end, your client server has to be signed by a CA that's trusted by the AAA server.
If you wish to understand the whole process a bit better, there's a great series of posts explaining how digital certs work:
http://community.arubanetworks.com/t5/Authentication-and-Access/Digital-Certificates-5-part-series/m-p/22752/highlight/true#M219
BR
Samuel Pérez
thanks for the info, i believe i understand the principle, it just didn't work out for some reason.
i now have a working setup with the the same CA for server and client certificate. im going to test some more so see what does and doesn't work.
Moderator
That's probably due to the client certificate format. I had a lot of trouble with my phone as well. Nevertheless, it ended up working when I used .pem format.
BR
Samuel Pérez
