Angle Mouting bracket AP-305
Hi everyone,
I have a customer with an installation that has high finished ceilings.  The customer wants the installation close to ehre they plan to pull cabling that does not affect the aesthetic of the room.  Unfortunately this is the corner of the room.  The ceiling also has large crown molding.  Is there an angle brackets for the AP-305?  The customer purchased the APs before I was engaged.
Thank you for any feedback in advance.
Re: Angle Mouting bracket AP-305
No such brackets are available from HPE Aruba, but you can reach out to our partners Oberon and Tessco/Terrawave. They offer angled brackets for our indoor APs.
