Another Android Connection Problem
Dear All,
I've just bought IAP-135, I have set everything and having problem connecting from LG Optimus L9 Android ICS 4.04 with latest firmware and Aruba OS 6.200.
I've searched the forum but find no solution, anyone can help me ?
Re: Another Android Connection Problem
in order for us to assist you,please explaing further your issue:
  1. add some screenshots of the SSID configuration
  2. add the confriguartion output from the instant (virutalap unit)
Case closed, after I turnoff and move to other place everything works fine. Thanks
