Frequent Contributor II
Another Captive Portal question...
So how do I extract Captive Portal default #2 (the one with the Email submission) so that it can be modified and still have the email submission piece still work. Doing a view source doesn't seem to cut it as a page created from that looks right but the email submission piece doesn't work.
As always, thanks in advance for any help :-)
Scott McNeil - IT Specialist, Global Process Automation
Network+ | CWNA | CWTS | ACSP | ACMP | ACMA | BREC
Re: Another Captive Portal question...
A.You should build another captive portal profile - and enable guest login.
B.in the new captive portal profile you create ,just enable - guest login .
(after u configure the captive like you want - dont forget to add it to you access role (that belongs to the AAA profile of the vap you would like to enable captive e-mail submission)
guest login = e-mail submission.
MORE INFO (ALL U NEED FOR USING CAPTIVE PORTAL)
Start Here:
http://www.arubanetworks.com/techdocs/ArubaOS_60/UserGuide/Captive_Portal.php
Then Go there here:
http://community.arubanetworks.com/t5/Command-of-the-Day/COTD-How-to-customize-the-Captive-Portal/td...
Here is a full HTML ready script for one time button (read all the post - and than download the needed files)
http://community.arubanetworks.com/t5/ArubaOS-and-Mobility-Controllers/Captive-Portal-Login-page-quo...
TO DOWNLOAD GOOD PDF'S WITH INFO REAGRADING YOUR QUESTIONS GO TO ANOTHER POST I DID:
http://community.arubanetworks.com/t5/ArubaOS-and-Mobility-Controllers/Single-Click-Captive-Portal/m-p/66488#M7800
have a lovely day.
me
BTW:
Another good post that might give u an idea - from where and how to start:
http://community.arubanetworks.com/t5/ArubaOS-and-Mobility-Controllers/HTTP-Script/td-p/13483
