- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Antenna Pattern plot request for AirMagnet Project
04-21-2016 12:09 AM
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
Re: Antenna Pattern plot request for AirMagnet Project
04-21-2016 07:05 AM
That's not something we (Aruba field SEs) would do for airmagnet, they would usually do that in-house and make a request to our corporate PLM for the data. If you have a PoC at AirMagnet you are working with, PM me with that contact info and I can work to get them the data that they would need.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
04-21-2016 07:07 AM
I'm sure you saw but the actual patterns are on the data sheets.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
04-21-2016 08:40 PM
Let's discuss with our supplier, would you please help to share the advise about value define to match with software & diagram plots assignment for our service supporting.
Model requirement :- AP-103H, AP-205H and AP-3200 series
Ring Count This value alters the number of concentric circles displayed in the field diagram. Count the number of rings in the product Antenna pattern diagram and enter the number here (include the outer-most ring)
0 dB Ring # Using the product Antenna pattern diagram, count the number of rings from the center to the 0 dB ring and enter the value here.
dB Interval Using the product Antenna diagram, determine the dB interval between each ring and enter the value here. For example, if there is a 5 dB interval between each ring, the value to enter here is 5.
0 Ring dB Using the product Antenna diagram, if the graph reaches the peak gain at any point, enter 0. If the graph does not exceed zero, enter the Gain value.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
04-22-2016 05:47 AM
Others can comment but these instructions don't make much sense to me either. As an example, to me just eyeballing, the 205H looks like, however, none of those values seem to be related to a planning tool building a proper antenna model. Additionally, is the software going to account for the H and V pol of the antennas? If not, which one are you going to use? The 103H and 205H are both rendered and designed to be desk or wall mounted, does the software account for that?
205H = 9, 8, 5dB, 0
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
04-29-2016 05:03 AM
Dear Guys,
Below please find the contact info for your reference. Could you please help to share related info for our service support team to follow those antenna plots issue.
Thanks for your help & coordinate.
techsupport@netscout.com [ ref:_00DU0JJ3b._500U0TBBZw:ref ]
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
04-29-2016 07:52 AM
It would help if you could provide a direct PoC to NetScout, or a case number, as well as what the purpose of the information is for specifically (what tool this is for on their side, etc, unless the PoC will explain it to me). I'm not inclined to reach out to a generic tech support email without specifics. Once I have a PoC or a support ticket number on the NetScout side, I will reach out to them to find out what they need. Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
