Antenna Type Identification remotely
I have IAP-204-RW APs. We are using 2 type of Antennas. Details of which are as below.
AP-ANT-1W
AP-ANT-25
Is there any way we can check remotely which Antenna is connected to which APs thorugh any commands or GUI?
Also I would like to know which dBi value we have to set under AP--> Edit --> Enternal Antenna --> 2.4GHz Antenna Gain and 5GHz Antenna Gain for both these type of Antennas (AP-ANT-1W & AP-ANT-25).
Please let me know if you require any more information.
Niren
Aruba
Re: Antenna Type Identification remotely
[ Edited ]
Unfortunately antennas are passive devices and there is no way to tell remotely what type is connected to the AP.  The info on the gain is in the datasheets.
http://www.arubanetworks.com/assets/ds/DS_AP-ANT-25.pdf
http://www.arubanetworks.com/pdf/products/ap-ant-1b_ss.pdf
ACCP, ACMP, ACMX #294
mclarke@arubanetworks.com
