Frequent Contributor II
Antenna Vertical & Horizontal Beam width
I'm not able to understand difference between Antenna E-Plan ( Vertical Beam Width) & H-Plan ( Horizontal Beam Width )  & relation between that & Antenna position
For example :
Ex1 :
AP-ANt-17
has
• E-plane :60/75 degrees
• H-plane : 120/150 degrees
What does that mean ?
Ex2:
what relation between Beam width patterns drawn @ the below link & between  haiving :  E-plane :60/75 degrees  H-plane : 120/150 degrees
http://www.arubanetworks.com/pdf/products/ap-ant-17_ss.pdf
Re: Antenna Vertical & Horizontal Beam width
There's a video in my 10 Minute Outdoor Engineer series that explains this.
http://www.arubanetworks.com/technology/engineer-videos/
Upper left corner, called "Understanding antenna types and patterns"
-cl
Yes ^^^^^^^^^^^^^^^^
Great video but it was moved.
New location is:
https://www.youtube.com/watch?v=YAxJtRTzGOc
(Or else google Antenna Vertical & Horizontal Beam width)
