Antenna for AP 104
I need to use a 120 degrees antenna with AP 104, but looking into the antenna matrix, the model AP-ANT-17 has 3 RP-SMA pigtails while the AP104 has 4 connectors.
What is the corret way to use this antenna ?
Regars
Thiago
Aruba
Re: Antenna for AP 104
The 4 connectors on the AP-104 are broken up; 2 for 2.4 and 2 for 5.0.  When using the AP-ANT-17 antenna, you only connect two of the connectors.    You'll need 2 x AP-ANT-17; each with 2 connections if you want to offer both 2.4 and 5.0 access.
AMFX | ACCX | ACDX | ACMX
Thank you!
