Frequent Contributor II
Any plan for MSR product?
Anybody know if there's a plan for Msr Mesh product?
the firmware is quite 1 year old and no new release... any plan to integrate in the controller or put a iap os on it?
Andrea Consadori
ACMP 5.0 and 6.3
Moderator
Re: Any plan for MSR product?
The MSR product line has been a solid performer for Aruba.
The MSR product line use cases are well defined and the product serves those use cases very well.
Aruba currently has no impairments wrt to fulfilling orders on this product.
Aruba is supporting and sustaining this line as active products
Aruba has no plans for new features on this product line
We use msr product hardly, they are stable but lack of security feature and avt streaming on tcp is still pendind, also support for more cameras
Andrea Consadori
ACMP 5.0 and 6.3
Super Contributor I
From the way it looks like development is going to be on passive mode for AIr Mesh product range. Shouldn't at least come out with the AC standard Air Mesh routers?
Normal Guy
