Anyone deployed IAP-274/275 at dock / marine / sea ports?
Hi Airheads ,
Good morning,
I would like to to get some info or advises from pepole that already deployed IAP/274/275 solutions at sea ports in order to connect 3rd part vendor ap-client. (that doing NAT to devices behind him)
Anything i need to know ? Any tips ?
Client would like to use 5Ghz.... (Isn't it a problem with weather radars or sea radars?)
Please advise.
Me
Re: Anyone deployed IAP-274/275 at dock / marine / sea ports?
I have supported a few marinas where they deployed AP-275s along the pier to allow their clients to use when on a boat, or to connect CPE types of devices to the AP-275. So long as you are using a crypto that the CPE devices will support, you should be fine. In most cases WPA2-PSK is perfectly acceptable.
Jerrod Howard
Sr. Techical Marketing Engineer
Contributor II
Are there any special requirments some places might require class1/div2 certified AP's.  Are these 274's and 275's certified for my reference?
C1D1 and C1D2 or ATEX are usually for explosive environments where there are combustible or harmful/corrosive vapors in the air (which should NOT EVER be the case in and around a shipping area or a pier).
If you do require that level of protection, say for a different environment, you would use the AP-274 and an Extronics enclosure that is certified for the use of our AP-274 in those kinds of environments. You can contact Extronics directly for more information but here is the data sheet.
http://www.extronics.com/media/391396/407298-3.1%20iwap107-ap274%20datasheet.pdf
Jerrod Howard
