Contributor I
Anyone encountering DHCP issues with OnePlus 1 devices?
Hi all,
We are encountering multiple issues on our Aruba Controller environment with recently Intuned OnePlus 1 devices.
Devices cannot connect to captive portal --> no ip address. Cannot connect to EAP-PEAP --> no ip address.
DHCP request is not received by DHCP server. Other clients on same network do not have this issue....
It seems an issue with the device, but you know, users first blame the network...
Re: Anyone encountering DHCP issues with OnePlus 1 devices?
What does the initial role look like on these SSIDs?
#show rights <role name>
Cheers
James
Contributor I
(xxxx) #show rights CPAP_HotspotHQ
Derived Role = 'CPAP_HotspotHQ'
 Up BW:No Limit   Down BW:No Limit
 L2TP Pool = default-l2tp-pool
 PPTP Pool = default-pptp-pool
 Periodic reauthentication: Disabled
 DPI Classification: Enabled
 Web Content Classification: Enabled
 ACL Number = 76/0
 Max Sessions = 65535
 Check CP Profile for Accounting = TRUE
 Captive Portal profile = CPAP_HotspotHQ
Application Exception List
Name  Type
Application BW-Contract List
Name  Type  BW Contract  Id  Direction
access-list List
Position  Name                       Type     Location
1         global-sacl                session
2         apprf-CPAP_HotspotHQ-sacl  session
3         ra-guard                   session
4         allow-clearpass            session
5         logon-control              session
6         captiveportal              session
7         cplogout                   session
global-sacl
Priority  Source  Destination  Service  Application  Action  TimeRange  Log  Expired  Queue  TOS  8021P  Blacklist  Mirror  DisScan  ClassifyMedia  IPv4/6  Contract
ra-guard
1         user    any          icmpv6 rtr-adv                 deny                             Low                                                           6
allow-clearpass
1         user    E_CPPM       svc-http                permit                           Low                                                           4
2         user    E_CPPM       svc-https               permit                           Low                                                           4
logon-control
1         user    any                      udp 68                 deny                             Low                                                           4
2         any     any                      svc-icmp               permit                           Low                                                           4
3         any     any                      svc-dns                permit                           Low                                                           4
4         any     any                      svc-dhcp               permit                           Low                                                           4
5         any     any                      svc-natt               permit                           Low                                                           4
6         any     169.254.0.0 255.255.0.0  any                    deny                             Low                                                           4
7         any     240.0.0.0 240.0.0.0      any                    deny                             Low                                                           4
captiveportal
1         user    controller   svc-https                     dst-nat 8081                           Low                                                           4
2         user    any          svc-http                      dst-nat 8080                           Low                                                           4
3         user    any          svc-https                     dst-nat 8081                           Low                                                           4
4         user    any          svc-http-proxy1               dst-nat 8088                           Low                                                           4
5         user    any          svc-http-proxy2               dst-nat 8088                           Low                                                           4
6         user    any          svc-http-proxy3               dst-nat 8088                           Low                                                           4
cplogout
Expired Policies (due to time constraints) = 0
Ok.
Can you try the legacy DHCP client? I'veheard this fixes some DHCP issues....
Developer options > Use Legacy DHCP client.
Cheers
James
Contributor I
Just tested this on one device and it works!! Thanks a lot!!
