Anyone have a definitive configuration for AP discovery using InfoBlox DHCP scope options?
The current posts are not definitive enough and the Aruba documentation shows very little theory that translates to InfoBlox terminology.
I DO NOT have the option to use DNS as my method of discovery. If someone who uses InfoBlox can give screen shots or something equivalent it would be helpful.
Trusted Contributor I
Re: Anyone have a definitive configuration for AP discovery using InfoBlox DHCP scope options?
Here's a post from another customer that explains how to configure InfoBlox DHCP scope options.
If a reply adequately addresses your issue, please click on the "Accept as Solution" and "Give Kudos" button so this information can benefit other users.
