Contributor II
Anyone have the AP315 LED status codes?
There used to be 4 LEDs on the APs, but I got a 315 and there are only 2 LEDs. Does anyone have the status codes for the 2 LEDs?
Does it just condense the 5Ghz and 2.4Ghz into a single LED? And remove the Ethernet LED all together?
That's my best guess but haven't found documentation to support. I have an Amber/Red light on that I'm hoping PoE power save.
For reference, this is the table I used to use.
Re: Anyone have the AP315 LED status codes?
https://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/EntryId/21953/Default.aspx
Installation Guide for the 310 Series
Frequent Contributor I
Hey there,
I have setup AP-314 with AP-ANT-1W. Function is good but Power LED is RED while Network LED is GREEN.
How can i get information what System Error condition the AP faces?
You should get the tech support from that AP.
Anybody know what the flashing amber light on the AP-303h means? Can't find any documentation
I found what I was looking for..
